VP44 or APPS
Old Nov 9, 2010 | 08:36 AM
bludodge21111's Avatar
Default VP44 or APPS
Hey everyone i have an 02 cummins mods are in the sig. im thinking i need a VP but im not sure and id like some input
Symptoms:
When truck is cold it starts right up but it runs rough and misses if you touch the throttle in neutral or park.
Then sometimeswhen you start going it will lose all power, almost identical to the dead pedal, but i cant get it to recover without turning the truck off and restarting.
Im also experiencing a dead pedal around 50 mph sometimes but not all the time and once the truck is warm i can just let off and get back on the throttle and it is fine.
The truck runs strong but fuel mileage has dropped off a little
So what do you guys think and do you think the VP44 or would it be worth throwing in a APPS?
Also what about the VP44 electronic fix at the top of this section.
Thanks in advance, James
Old Nov 9, 2010 | 09:47 AM
Any Codes?
Hows fuel pressure?
Old Nov 9, 2010 | 12:09 PM
Ill have to get back to you on codes im not currently at the truck i have an airdog 150 that runs 19psi at idle and 16 psi WOT. Thats been on for a year prior i ran it for 2 months with only 7 psi. Before i really new anything about the fuel systems.
I do have codes though i just dont remember which ones
ok i checked and...
P PCU: 1693 and 0500
P ECU: 1693 and 0216
thanks again
Last edited by bludodge21111; Nov 9, 2010 at 12:09 PM. Reason: Automerged Doublepost
Old Nov 9, 2010 | 12:27 PM
0216 is a death code
Your going to need to replace your Injection Pump
Old Nov 9, 2010 | 06:12 PM
Thats what i figured thanks for your help can u pm me a quote
Old Nov 9, 2010 | 06:33 PM
mishkaya's Avatar
Originally Posted by bludodge21111
ok i checked and...
thanks again
P0500 is a speed sensor, but as lukesdiesel said, P0216 is pretty much a guaranteed VP44...
Old Nov 9, 2010 | 08:33 PM
As far as the speed sensor goes where is it located and that code comes and goes should i really worry about it? could it be from my edge box?
As far as the injection pump maybe a P pump conversion
justinsbeck
Jan 18, 2016 12:15 AM
jeremiah1
Jun 21, 2015 06:45 AM
DeLuzGN
Mar 17, 2015 08:08 AM
JPT18
Dec 30, 2014 11:37 AM
somarillw
Dec 15, 2014 12:00 AM
