Input Shaft Bearing
Old Nov 8, 2010 | 09:36 PM
6.5L's Avatar
Default Input Shaft Bearing
I just bought a 92 dually 5spd and the guy the day i bought it said that the input shaft bearing was making a noise how hard of a fix is this and about how much will it cost me?
Old Nov 9, 2010 | 06:23 AM
kieron_kohlmann's Avatar
its doable by yourself. you just have to take the transmission off and remove the front. bearing cant be that expensive. Id just be concerned if it actually is the input bearing. When you change it you mine as well see how your clutch/pressure plate/ pilot bearing etc. are doing. It might be worth changing them too.
Old Nov 9, 2010 | 09:41 AM
Mark Nixon's Avatar
What make of vehicle? Engine?
Getrags in a Dodge are noted for needing rebuilt, it's pretty much a given at this age.
There are, technically no "cheap fixes" for "bearing noises" from the tranny, even "a simple throwout bearing" can easily work into needing a $300-$700 clutch job.
Or more, if you find internal tranny damage while it's apart.
Mark.
Old Nov 10, 2010 | 12:37 AM
big bad diesel 416's Avatar
Site Sponsor
if its just the "bearing" I would kit it since its that far out bearing kits go for 70-150 bucks and a full rebuild kit for 200-300
oznation
Jul 28, 2015 02:54 PM
RedChevy44
Apr 21, 2015 05:47 AM
Greywolf
Feb 17, 2015 06:37 PM
woodsman27
Dec 9, 2014 09:55 AM
