dropping trans
Old Nov 8, 2010 | 09:33 PM
94 5 speed's Avatar
Default dropping trans
im changing my clutch in my 94 12v to change the clutch. my problem is that on the cross member i cant get to the top two nuts that are in the frame. are they supposed to be just threaded to the frame or am i doing something wrong
is there an easy way to just moving the trans back to switch the clutch?
Old Nov 9, 2010 | 05:17 AM
95 12v's Avatar
you should be able to get to the top two nuts with a couple extensions and a wrench. I personally think its easier to unbolt the transmission from the bell housing first it makes it easier to get to the bell housing bolts it was just easier to me
Old Nov 9, 2010 | 10:26 AM
cumminspwr11's Avatar
just use like a 2+foot extension and the bell housing bolts a easy, the cross member bolts should come out pretty esay, there are nuts on the backsides inside the frame, the first few times i pulled the cross member is was told to use a big hammer and work it out form between the frame rails, then someone showed me what a porta power was all about,
Old Nov 9, 2010 | 11:20 AM
1AMatt's Avatar
Site Sponsor - 1aauto
I believe there should be a hole cut in the other side of the frame, for you to access the nut on the inside of the frame. A big extension and you will have no problem
Also, the cross member is usually pretty snug between the two frame rails. If you have trouble smashing it out with a sledge hammer take a bottle jack and a 2x4 to spread the rails apart a little bit. Then it usually comes out with minimal effort.
Old Nov 9, 2010 | 02:51 PM
94 5 speed's Avatar
i got the crossmember off and all the bellhousing bolts and now the shifter assembly is getting caught on the floor i cant see how to get it out
Old Nov 9, 2010 | 04:34 PM
it will either have a few 10mm bolts to pull out on the top of the trans or it will be a spring loaded thing that you have to push down and twist, its a real bitch sometimes, im sure there is a special tool for it but i was dick around with different shaped pliers until i get it
Old Nov 9, 2010 | 10:11 PM
joshmock's Avatar
yeah, he's (cumminspwr11) right. i had a youtube video of it but couldn't find it. just find something that fits down into the top and on either side of the shifting nub sticking up - hence maybe a wrench. push down because it's spring loaded and turn to the left i think, after a couple precise and calculated tries it should pop out for ya.
Old Nov 12, 2010 | 08:26 PM
getting out is easy its putting it back in thats not fun
Old Nov 12, 2010 | 10:21 PM
94 5 speed's Avatar
well couldnt get the shifter off but it turns out the previouse owner cut a little channel out in the floor to drop the trans. im glad cause i could not get the shifter off for anything
Old Nov 12, 2010 | 10:30 PM
dan33klein's Avatar
you use like an 1/1/8 open ened wrench to pry down and turb counter clockwise. then the shifter comes right out
