Turbo Question
Old Nov 8, 2010 | 08:28 PM
Captn_tyler's Avatar
Default Turbo Question
I just installed my new turbo, and I got a few concerns
1. When I removed the turbo from the box the turbine didnt spin as free as I figured it should.
2. My egts have gone up
3. my boost seems a little too low
I did pre oil the turbo, and changed the oil in the engine. I checked all connections but will double check
Is it possile the new bearin just needs to be broken in?
Old Nov 8, 2010 | 10:34 PM
RAW's Avatar
RAW
I highly doubt it. It should be free spinning and good to out of the box. I'd contact the distributor and tell them whats going on. They may suggest running it longer to see if things improve, but at least they know the situation.
Old Nov 8, 2010 | 11:15 PM
Farmboy 2.0's Avatar
Yeah what make of turbo is it may I ask or whos turbo is it?
Old Nov 8, 2010 | 11:27 PM
Its an Industrial Injection Phat Shaft 62/65/14.
When I say it doesnt spin as free, I dont mean it binding, it just slows down pretty quickly, like there is drag on it. With a pretty good spin, i would say I was gettin between 5-10 revs.
Old Nov 8, 2010 | 11:33 PM
It should take about 400 miles to get broke in well and the bearings to loosen up!!!!!! My turbo was pretty tight when i got it
Old Nov 9, 2010 | 07:11 AM
johnyb59's Avatar
How are your egt's with the box turned up? same with boost. How are your WOT egt's compared to your old turbo. Its possible that you maybe under-fueled.
Old Nov 9, 2010 | 09:20 AM
Keep in mind a good turbo is more efficient so your boost numbers will be lower than with the stock turbo. The new turbo will have a much closer 1:1 drive pressure ratio.
Old Nov 12, 2010 | 01:30 AM
01quadcab's Avatar
you still only running rv275's? if so you need more fuel.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
