Garrett turbo ?
Old Nov 8, 2010 | 12:12 AM
95 12v's Avatar
Default Garrett turbo ?
i can get a good deal on this turbo but i dont know anything bout it i did some research and it said that its either a GT4294R or a GTX4294R on the compressor housing it has Ar .60 M-24 i need some help guys is it worth it for a good price or would it make an ok street/strip turbo ?
Old Nov 8, 2010 | 11:24 AM
94 12valve's Avatar
the gtx chargers are suposed to be next big thing in turbo charging should be an 11 blade compressor wheel, the GT model is also good.
Guess it depends on what you call a good price?
Old Nov 8, 2010 | 04:11 PM
95 12v's Avatar
well the big ? is it streetable i can get it for 900 bucks
Old Nov 8, 2010 | 08:33 PM
94 12valve's Avatar
what do you have for mods?
Old Nov 8, 2010 | 09:18 PM
95 12v's Avatar
4gsk,#4 plate, 4 inch straight pipe, 191 dv, 370 marine injectors, cold air, pump has had alot of work done to it, studed, new transmission, and SBDD 3850 non-slipper sled pullin disks, i was makin 56 psi with my stock turbo till it blew ha i put another stock one on and still made 56 psi with the hx 35!
Old Nov 8, 2010 | 09:42 PM
12vcummins96's Avatar
you should spool it fine
Old Nov 9, 2010 | 02:28 AM
95 12v's Avatar
well i use the truck as an everyday driver and pull stuff with it as well
or should i go with a phat shaft silver bullet 66 i can get it fairly cheap brand new still in the box
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
