HELP PLEASE
Old Nov 6, 2010 | 05:43 PM
BIG RON's Avatar
Default HELP PLEASE
i got a 91 cummins been running fine, this mornin it acted like it was running out of fuel and died cant get it goin again. I cracked the line from the fuel pump to filter got fuel, cracked line at injector pump got fuel, went around cracked injectors,bled them off , fired off and ran a few minutes died again. I changed fuel filter still the same, got a fuel pump comin, if that dont work what could it be?????
Old Nov 7, 2010 | 12:53 AM
dieseldawg's Avatar
sounds like its getting air in there!! could be the lift pump though!!
check your fuel lines carfully!!
Old Nov 7, 2010 | 06:23 AM
Rusty89Cummins's Avatar
try pressing down on the primer lever on the lift pump. if it feels like its not doing anything then it could be shot. ive gone through 3 in the past 3 years no. ever time it seems like the same thing. it will still supply a little fuel that will make it seem like its working but its really not. has your truck been sitting out in some cold weather the past few nights?
Old Nov 7, 2010 | 06:33 PM
Mark Nixon's Avatar
Just had the lift pump shoot craps on me last week, on the car hauler.
I went and paid the ~$110 for Speedway's version of the Holley "Black" pump.
Yeah, it is a bit noisy, but this truck starts and runs better now, than it has since I did the Cummins conversion on it over a year ago.
It is likely I will not run a stock POS lift pump on anything I own again that has a VE.
Mark.
Old Nov 7, 2010 | 07:21 PM
Rustin's Avatar
Well you definetly have fuel issues. Have you tried testing for pressure, while trying to start?
Old Nov 8, 2010 | 11:12 AM
Levi Miller's Avatar
hey mine did the same thing i would deff replace the stock lift pump i learned the hard way i didnt know either and i burnt up my injector pump, turns out it was one little 30 dollar lift pump you can pick up from a local parts store then also its a better idea get a electric fuel pump like a holley blue or black there like a 100 to 150 bucks aint much compared to a 800 dollar injector pump
Old Nov 8, 2010 | 04:40 PM
BIG RON's Avatar
I changed everthing, checked pressure, no leaks no air being drawn, guess its time to buy a IP thats suks
