smells?
Old Nov 6, 2010 | 05:25 PM
0331grunt's Avatar
Default smells?
I pulled a trailer yesterday, about 13,000 lbs, and when I got to drop it off, I smelled what smelled like hydraulic oil. Are the manual trans on these trucks hydraulic and what would cause it to smell? I don't see any leaks anywhere. It ran fine @ 65mph for over 100 miles, fairly level interstate roads. Just curious. Only had the truck about a month. Thanks.
Old Nov 6, 2010 | 11:09 PM
dangerous1965's Avatar
Over full diff will do that! and or tranny! Check the breather tubes.
Old Nov 7, 2010 | 01:18 AM
Sirwrenchiezolot's Avatar
the trany and transfer case use atf+4 and the diffs use gear oil so i would check them u could possibly have a leak somewhere I know the pinion seals are a common leak on these trucks.
coolf250
Dec 2, 2017 12:30 PM
countryboy040993
Apr 25, 2016 01:36 PM
wpg6.5
Mar 22, 2015 12:38 PM
