Wait to start never comes on
Old Nov 6, 2010 | 03:44 PM
jrok's Avatar
Default Wait to start never comes on
I am new here and new to the cummins. But i so far love it. NE ways, my wait to start light never comes on. what could cause this?
Old Nov 6, 2010 | 09:16 PM
JDcummins's Avatar
Mine don't come on either but when its about 40degrees out mine turns on or when its colder
Old Nov 7, 2010 | 12:52 AM
dieseldawg's Avatar
it only comes on when its needed!!
a cummins doesnt need much help to start like a flowerstroke does!!
Old Nov 7, 2010 | 10:40 AM
RSWORDS's Avatar
https://www.dieselbombers.com/1st-ge...id-heater.html
Old Nov 7, 2010 | 08:10 PM
Billy D's Avatar
Yeah!!!
Old Nov 21, 2010 | 11:27 PM
rick390's Avatar
mine wont come on either but the relays work as i can hear them . but i swapped in another pcm and wts lamp worked .
Old Nov 22, 2010 | 01:40 AM
Thekingrulz69's Avatar
Mine always comes on. even when its hot out. Does that mean anything?
Old Nov 22, 2010 | 01:52 AM
rick390's Avatar
i dont think any thing will happen but you may have a discrepancy on coolant sensor or intake sensor one of them may be showing the pcm that its -40 degrees
Old Nov 22, 2010 | 03:04 AM
FastCR's Avatar
If it doesn't get below 60-70* where you are I wouldn't worry about it too much, but if it gets cold I'd fix it. Make sure the grid heater is kickin on. On the ve/p pump trucks the main functions of the pcm are cruise control and grid heater. It's $$$, so I'd check if grid heater is kicking on and the light isn't working. If thats the case, eff it. If grid heater isn't working at all, you might consider a relayed momentary switch to kick it on when it gets cold, then start. If it starts, it starts, but some increased engine wear can be expected IMO from starting REALLY cold with no grid heater. (as I do)
Old Nov 22, 2010 | 03:56 AM
dwstaples's Avatar
Did you check the bulb when you first turn the key on. all lights should come on. I have 4 blown bulbs,so my 4X4,4X4low, and 2 others never light up
schwier94
Sep 26, 2016 09:07 AM
ronstop
Feb 26, 2015 09:48 AM
bullrideris1
Jan 23, 2015 09:22 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
NCC74656
Nov 4, 2014 10:46 AM
