It runs slow from cold starts ??
Old Nov 6, 2010 | 01:39 PM
bdcummins's Avatar
Default It runs slow from cold starts ??
2000 Ram 2500 24v 4x4 auto , Air Dog 100 is the only mod and I had this problem before and after the the Air Dog kit
No codes
runs slow at first for about a mile or 2 then it will get down to biz as normal
its like its in limp mode
feels like its stuck in 4th gear or OD
when i start the truck in the morning or even just after its been sitting for longer then 5 or 6 hours it will do this its very frustrating
I can even let it run at idle go back in the house for 5-10 min come back and drive off and it will be doing this problem for the first mile or 2
WTF
Please help the truck is flawless other wise
Old Dec 30, 2011 | 05:51 PM
jrswoodworking's Avatar
Hi did u ever figure out why?
My 12 valve is starting to do that.
Thanks.
Old Dec 30, 2011 | 06:37 PM
wilke12V's Avatar
Check your codes...I had the same thing...I put a chip in mine and it fixed it. but it was really my vp44...so the timing of the chip helped me...check your codes And see if any vp codes come up
Old Dec 30, 2011 | 06:53 PM
Thanks but mine is a 12 valve no chips for me.
Will probably get my p-pump checked out then.
Thanks again.
Old Dec 30, 2011 | 09:25 PM
wilke12V's Avatar
Try asking the folks in the 12v section they might have some good advice for you...either way mine was a timing issue with the injection pump. I don't know if it could be the sane concept
BolinBunch
Jun 17, 2015 11:13 PM
dandbmcc
Mar 14, 2015 11:05 PM
plumberjack
29
Mar 3, 2015 11:38 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
bdemutis
Dec 7, 2014 01:36 AM
