6.9 help
Old Nov 4, 2010 | 06:29 PM
tb6.9ford's Avatar
Question 6.9 help
ok so when i start my truck i notice that all my lights dim when it starts, and when i give it throttle the lights get brighter. Im thinkin it could be the alternator is bad or that my battries are shot. Any ideas?
Old Nov 4, 2010 | 06:32 PM
prison's Avatar
test the alternator. mine did it some too but it didnt bother me
Old Nov 4, 2010 | 10:02 PM
DieselCrawler's Avatar
i would say alternator
Old Nov 8, 2010 | 10:49 PM
Sycostang67's Avatar
I've had that issue caused by bad grounds and a bad voltage regulator.
Old Nov 14, 2010 | 12:03 AM
tb6.9ford's Avatar
what would be the best size alternator to get?
Old Nov 19, 2010 | 07:17 PM
Hegel122's Avatar
if u test the alternator also have the battery tested... if those are good then you have a bad chassis ground...
Old Nov 19, 2010 | 09:51 PM
wreckinball's Avatar
just get a 130 amp and get it over with!! haha. napa carries them and mine works perfect!!
Old Nov 22, 2010 | 07:40 PM
tb6.9ford's Avatar
well i tested the battries after a full cahrge and one came up round 12 and the other didnt even hit 8 so tht could be my problem too. but i also need new cables cause the ones i got now are shot.
Old Nov 22, 2010 | 08:37 PM
If the batt tests bad, no cable will help that! You definitely have your problem!
Old Nov 23, 2010 | 10:19 PM
green thang's Avatar
deo the voltage regulator cuz i did the same went through 4 batts and 2 alt turned out the frekin 10 dollar voltage regulator
