High Idle
Old Nov 6, 2007 | 06:59 PM
bob32racing's Avatar
Default High Idle
I went to the dealer today and had my high idle set. $84 But i was reading more about it and it says
intake manifold temp must be inder 32 degrees
coolant temp under 140
I guess what i am asking about is there any way to fool the intake manifold temp. So i could get heat faster when the temp is below 140.
Old Nov 6, 2007 | 08:20 PM
Well thats the part that sucks you have to meet all the permissives for it to kick in. I would think there would be a way to fool it - but arent smart enough to know how.
Old Nov 7, 2007 | 09:10 AM
Bosshogg's Avatar
Just sit tight, I'm working on that
All I need to find are the connectors for the IAT and ECT to finish the project.
I've got my wiring diagram worked up to where you can select high idle or 3 cyl shutdown at any temp as long as the other parameters are met.
Old Nov 9, 2007 | 08:51 AM
GetBlown5.9's Avatar
im just waiting for one of the brand name companies to come out with a plug in box that just plugs into the APPS and is a high idle controller
Old Nov 9, 2007 | 09:06 AM
Ben's Avatar
Ben
The other kicker is that if you have if plugged in at all for a while before you start it up, the high idle doesn't come on.
At least on mine it doesn't. So that leaves me with the stick in throttle option....
Old Nov 9, 2007 | 10:21 AM
I have one - a local guy used to make them for the local Cummins shop - Id hook you up but he doesnt make them anymore.
These guys have them but they are stupid expensive for what you get: http://www.dieselservices.com/html/d...e_ram_p137.cfm
Old Nov 9, 2007 | 10:34 AM
Wyatt Earp's Avatar
Why muck with the electricals? Just install an exhaust brake. Idle all day with it engaged.
Old Nov 9, 2007 | 11:10 AM
Or an ESPAR or Webasto heater.
Good call on the exhaust brake - much better than the high idle since they actually put a load on the engine.
But again, not cheap and not exactly good on autos.
Old Nov 9, 2007 | 11:21 AM
some guys on DTR were building them last year.
i want a one that comes ready to plug and play tho, those guys had to go in and tap a few of the APPS wires, and i dont like that, i want a male-female type plug that goes inline on the APPS
Old Nov 9, 2007 | 12:59 PM
Wyatt Earp's Avatar
DR. Evil, sure but for $1300 or so you get the high idle AND a break. Otherwise you spend $500 + to just get heat and potential of electrical error.
It would work with an auto if you put it in neutral? I thought this was the case but maybe not.
