Disable seat belt chime?
Old Nov 4, 2010 | 12:02 PM
6.7 MoJo's Avatar
Default Disable seat belt chime?
I remeber seeing a post on here how to turn off that annoying seatbelt chime, I used the search tool with no luck. I remeber something about a sequence of turning the key and hooking and unhooing the seat belt but i dont remember.
Any help, its an 08.
Thnx
Mike
Old Nov 4, 2010 | 05:06 PM
cummins95's Avatar
i believe some tuners allow u to do this. i know its apples n oranges, but my boss has a 6.4 stroke with an sct tuner n he turned off the chime.
Old Nov 4, 2010 | 11:54 PM
m1911a1's Avatar
Thnx
Mike
I used my H&S to turn it off, I know that doesn't help but-
Old Nov 6, 2010 | 08:58 PM
08Ram2500's Avatar
If I remember you Start with the key off and belt buckled. Then turn the key to the run position and disconnected and connect the belt 10 times in 30 seconds. I did mine along time ago if you have the owners manual it's in there.
Old Nov 6, 2010 | 09:15 PM
barkrulz's Avatar
08RAM, did that turn the light off as well or just the chime. Mini maxx only turns off chime, red light stays on. would think if there was a factory override it would shut light off as well.
Old Nov 6, 2010 | 09:42 PM
08Ram2500's Avatar
That only does the chime.
Old Nov 20, 2010 | 11:52 AM
bmack31's Avatar
my truck had a seatbuckle in the midle of the bench and i just cut the buckle of the rope and plugged it into the buckle on the drivers side but thats an 09 ford
Old Nov 20, 2010 | 11:58 AM
92typhoon937's Avatar
my 07 had a procedure in the owners manual u had to follow but it left the light on the dash all the time which didnt bother me cause the chime is annoying
Old Nov 25, 2010 | 06:57 PM
EricBu12's Avatar
Yep, only the chime.. worth it though
Ironmanqb
Apr 4, 2015 10:27 PM
denpenn
Feb 11, 2015 11:29 PM
Cummins_Power_13
Feb 4, 2015 09:55 AM
mnbf48
Jan 19, 2015 09:20 PM
Floydfan38
Sep 28, 2014 06:21 PM
