Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
MF 165 Steering Question
Old Nov 4, 2010 | 08:32 AM
Uncle Bubba's Avatar
Default MF 165 Steering Question
My old Massey has developed a fluid leak in the steering system that I can't figure out. Right behind the dash is what looks like a steering gear that the shaft goes into. I can't find any grease fittings, no filler cap or drain and worst of all the manuals I have don't show anything being there. So where is this leak coming from.
Old Nov 4, 2010 | 09:01 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
if you are talking about power steering they are no fluid there. power steering on these tractors are on the front end. the only thing in there where you are talking about is a worm gear. there is a plate that you take off for service. call if you want. maybe i can help.
Old Nov 4, 2010 | 09:11 AM
Thanks Pap. Ya it's power steering. We rebuilt the hydraulics last year cause it was leaking. Still steers great, just tryin to figure out what's leaking. Above it is dry and nothin around it in the way of fluids.
Old Nov 4, 2010 | 09:15 AM
diesel pap's Avatar
i would like to have a little more info in where it is leaking.
Old Nov 4, 2010 | 10:02 AM
Farmboy 2.0's Avatar
Have you checked the seals to see if they are worn
Old Nov 12, 2010 | 07:19 PM
Well, steering has turned into the least of my problems now. Time for the rebuild. The Hydraulics are gettin weak and it needs a new clutch. Guess it's gonna be a busy winter.
It's startin leavin an oil slick behind it the other day and it looks like it's makin it's own oil again, Leaking diesel into the oil. That was the final straw that it's time to work on it. Looks like the injector pump seal is leaking into the block.
Old Nov 12, 2010 | 10:21 PM
diesel pap's Avatar
my 50 done that. it was that stupid heater you was talking about that was leaking diesel in mine. it run out the front seal. dont run it too long with diesel in the crank case. it will take out the bearings. dont ask how i know
Old Nov 14, 2010 | 10:11 AM
At this point, as long as money holds out it looks like it's gonna be a complete rebuild on the hydraulic pumps, clutch, engine and injection pump. The rear differential is in question. It's got some popping in one side but we haven't decided if it's bad enough to pull it apart again.
What I can't figure out is the fact that the motor oil still looks good, is holding a steady level and doesn't smell like diesel. But All this oil leaking out is coming from someplace.
Old Nov 14, 2010 | 01:27 PM
diesel pap's Avatar
before you rebuild the hyd. system, replace the relief valve and see if that was it. if not they are not hard to rebuild.
Old Jan 12, 2011 | 07:11 PM
farmingsthelife's Avatar
I've worked on a few Massey's and they (atleast the smaller tractors) have the worst steerign systems EVER.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
