98 12 valve pump
Old Nov 3, 2010 | 11:31 PM
blazier18's Avatar
Default 98 12 valve pump
wat is the benefits of having my pump flowed
Old Nov 4, 2010 | 12:39 AM
Farmboy 2.0's Avatar
to know what its doing and give a good idea what its capable of i guess
Old Nov 4, 2010 | 11:30 AM
94 12valve's Avatar
balance each plunger and barrel for the same amount of flow and the pump shop can also trun the barrels allowing more fuel to be flowed. The shop will be able to tell you what your pump can flow in the form of cc, can also mark on the housing where you need to put your plate to make said cc numbers. for example my pump was benched at 550cc with no plate 500cc with the plate FF.
Old Nov 4, 2010 | 12:02 PM
blazier18's Avatar
is that maxed out?
Old Nov 4, 2010 | 12:44 PM
shortbusdriver's Avatar
you can also have the timing adjusted.
Old Nov 4, 2010 | 03:19 PM
94 12valve's Avatar
is that maxed out?
yes, I was told with a stock cam that is the max, for a 12mm.
your right forgot about the phase timing
Old Nov 4, 2010 | 08:54 PM
blazier18's Avatar
so the correct timing and pump flowed and everything in there and the afc adjusted wat additional hp should that be
Old Nov 4, 2010 | 09:04 PM
94 12valve's Avatar
depends on how much fuel you can burn ... by that I mean your gonna need some air
Nilson12
Sep 15, 2015 10:02 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
btg2820
Apr 27, 2015 12:09 AM
bonestock
Feb 1, 2015 08:41 PM
