It's Broke AGAIN
ok driving back home from an inteview (30miles each way)
and wound brakes felt a bit soft.i figured it ws no big deal as the was raining and might have to do with something like that
well ont eh way home my abs and brake light came on..
wtf
ive reaplced every brake component there is, ive replaced all electronics there are..
i dont even know where to start..:help:
wtf
any chance during this rain you were doing any burnouts, wheel peeling etc. if you take off and keep spinning your wheels FAST in the rain it will trip a sensor that will go away on its own
^^^ i agree. if it's doing it only in the rain then start checking connections. especially any connection affected by tire splash. pull 'em apart and look for the greenies. clean 'em up and put a dab of dielectric grease.
how'd the interview go?????
intresting...... master cylinder was bone dry... i followed all the brake lines.. no leaks. followed the hydroboost lines. no leaks.. no leaks on calipers or cylinders..wtf only thing i can think of is powersteering/vac pump leak.. powersteering ran low so it sucked it from m/c?
you can't see any fluid leaks mobs? do the hydroboost master cylinders have a seal in back of them to hold fluid in? mine has vacuum booster so i don't know. but... the rear seal on my master started leaking and all the brake fluid was going into the booster. maybe you have the same problem.
did u pull ur rear wheels and look at the wheel cylinders?
no i didnt pull the wheels normally if you have a substancial leak, itll drip down on the inside of the tire from the bottom of the drum., i cannot see any leaks.. i followed all brake lines and such.
back of the master cylinder is the only thing i can think of then. like i said, i've seen the regular vacuum boosted master cylinders leak there.
