Injector Lines leaking
Old Nov 3, 2010 | 02:20 PM
bigdan120's Avatar
Default Injector Lines leaking
I have a 1995 Cummins 12 Valver P7100 pump and the lines are leaking on the pump where the line enters the nut. I have tightened a couple times is there a seal or fix it for this? I have them tight as hell now and they still leak!!!!!!!!!!! AAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHH
Old Nov 3, 2010 | 02:55 PM
12vcummins96's Avatar
sounds like you have overtightened the lines i hope you have not damaged the farrell on the line if you have you will be replacing the lines
good luck bud try backing them off and retightening them
Old Nov 3, 2010 | 03:06 PM
94 12valve's Avatar
make sure there not cracked, I have a stock set if you need them
Old Nov 16, 2010 | 06:59 PM
rockymtn's Avatar
Hi,
not sure if this is too late? Do you still have a stock set? How much? I have the same problem as Bigdan120. Also do you have a return line set?
Thanks
Russ
Old Nov 17, 2010 | 12:22 AM
joshbaker's Avatar
Are You sure its the lines? I know that a somewhat common problem is the o ring that goes in with the delivery valves have a tendincy to leek. (personal experience) and i thought it was a line. When you tighten the lines try to wiggle them a little when tightening them to make sure they are in the right spot. just my .02c for what its worth.
josh
Old Nov 17, 2010 | 07:13 AM
rockymtn's Avatar
Hi,
aren't the delivery valves on the IP itself? My leak is on the injector so not sure if it's the injector itself or the return line or the Injection line but when I removed them to install the new injectors they were very tight and it seemed like the ferrul part twisted a little which is why I suspect the injection line. Thanks for your insight though.
Old Nov 17, 2010 | 01:19 PM
joshbaker's Avatar
Oh i see what you are saying man. And yes the dv's are on the IP. Sounds like you will want to 94 12valve bout his lines.
Old Feb 9, 2011 | 10:50 AM
bigdan120's Avatar
Just wanted to let you all know I'm stupid...LOL The leak I thought was coming from my lines was from my stupid Dip Stick LOL After I seen another one doing the same thing.............
Old Nov 11, 2013 | 09:36 AM
Drunkasschicken's Avatar
Hey 94 12 valve do you still have those lines? i got a 95. been getting it in-tune. had to to have the pump off and get the afc holes machined where the preivious owner drilled out and ruined every thread... long story short. a few lines are bent, and he had them so tight i had to break them loose with a hammer. So when i snugged them back there now leaking, not bad but there leaking. both injector and dv sides
Old Nov 11, 2013 | 03:56 PM
94 12valve's Avatar
No I do not I got rid of them a year or so ago
|WYG|SS
Apr 28, 2015 03:59 PM
bryan0702
Mar 18, 2015 05:03 PM
dieselpowa
Feb 7, 2015 10:07 PM
Stox5225
Nov 18, 2014 01:04 PM
WickedEvo
Oct 20, 2014 10:50 PM
