Performance Enhancers
Old Nov 2, 2010 | 08:42 AM
Bikerboy96's Avatar
Default Performance Enhancers
I have a '02 2500HD with 78K mi. and running well. I pull a 5th wheel 'B' train(2 trailers) to snowbird territory each winter. I am considering a power upgrade for a little extra boost on the hills and getting around overloaded transports. I am considering the Hypertech E-Con model 33001 that advertises a boost of 73-94hp and torque boost 120/155 ftlbs. What are the drawbacks or risks in using these programmers? GM has increased the power output of newer models, does this mean I can too?
Old Nov 2, 2010 | 08:45 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Go for it. But I wouldn't use a superships. I'd put a PPE standard on it myself.
Old Nov 2, 2010 | 12:09 PM
Hypertech's Avatar
The Hypertech products for your vehicle are all set with tuning up to stage 3 that can be used up to the max capacity (load/haul) as set by the manufacturer.
If you are towing or hauling more than allowed you should tune to a lower setting.
The actual tow weight will decide the difference.
We monitor the EGT at pre -turbo with precision probes to maintain a safe level based on the mfg. specs.
GW
Hypertech Inc.
Old Nov 2, 2010 | 12:45 PM
Default Re: Performance Enhancers
PPE
Sent from my Fission Droid2.
Old Nov 2, 2010 | 04:11 PM
Bikerboy96's Avatar
What is EGT, and what am I monitoring? I am only pulling about 9000lbs gross, plus 2 people ~9400lbs (GVWC ~12000).
What is a PPE standard?
Old Nov 2, 2010 | 05:03 PM
Jagsdiesel's Avatar
EGT= Exhasut Gas Temp.
The PPE standard is their smaller programer and does not have as high of power levels as the hote+2. Its a great tow tune. We have an 02 with 60hp injectors and a standard on it. Pulls like its not even pulling anything.
Old Nov 7, 2010 | 07:10 PM
mylilpwny's Avatar
there is all so the ppe econ tuner gives a nice kick and cheaper then the standard
NDPspeed - Your online Speed Shop - Economy Xcelerator Duramax LB7/LLY/LBZ/LMM
Old Nov 16, 2010 | 11:38 PM
cstlb7's Avatar
ppe boost valve and standard ppe would be my best bet, i have the ppe boost valve kinda like a j hook on a dodge i get and extra 3 to 5 psi out of it well worth the $60 and from what i have been told hypertech is a tranny killer
Old Nov 17, 2010 | 08:59 AM
Hypertech's Avatar
Since the vehicle has the Allison transmission which Hypertech Does Not provide any tuning for I think you may gotten some incorrect information
No problem, just thought I would let you know.
GW
Hypertech Inc.
carid
Diesel Bombers Sponsors
Nov 2, 2015 09:58 AM
Jul 18, 2015 10:10 AM
carid
Dec 12, 2014 02:26 AM
Paintrain64
Nov 25, 2014 06:29 PM
Nov 3, 2014 01:40 PM
