hard starter
Old Oct 31, 2010 | 09:04 PM
92 cummins's Avatar
Default hard starter
does anybody else have a hard starting PSD, mine knocks and almost has a lopey sound to it, it does for about 5 min and then after that it is fine
Old Nov 1, 2010 | 10:27 AM
MUDSTROKIN''s Avatar
Load test your batteries and Test your FICM. Let me know the results
Old Nov 1, 2010 | 07:46 PM
newman's Avatar
How long since your last oil change?
Old Nov 2, 2010 | 09:10 AM
Mdub707's Avatar
Fuel filters and oil change will help. I'd be money on glow plugs though, or glow plug harness. FICM and injectors also need to be tested. The problem with this is it's a simple problem, but it has a LOT of possible solutions.
Old Nov 4, 2010 | 08:22 PM
92 cummins's Avatar
thanks, and the oil and filter were changed about 1,000k ago
Old Nov 4, 2010 | 08:44 PM
jimrd's Avatar
did you tryand plug it in at night to see if there is a difference
My truck does the same thing when not plugged in
Old Nov 5, 2010 | 08:43 AM
Mdub707's Avatar
What about fuel filters?
Old Nov 5, 2010 | 11:42 PM
92 cummins's Avatar
mine didn't come with a plug in from the factory. and i will check the fuel filters
Old Nov 6, 2010 | 12:11 PM
Mdub707's Avatar
It might have it, you would have to get under the truck and look, they're usually zip-tied out of sight. If not, the block heater IS there, but the cord is not. Starting in 05 the cord became an option believe it or not. You can get them on ebay for around $20.
Old Nov 6, 2010 | 02:53 PM
92 cummins's Avatar
if i wanted it i had to make a speacial order, but ill look into the block heater cord, illl definetly need it for winter.
