How heavy is the flywheel on these babies ?
Old Nov 1, 2010 | 01:21 PM
angelic0-'s Avatar
Default How heavy is the flywheel on these babies ?
How heavy is the OEM flywheel ?? 30-40kg ????
Is there any weight difference between the OEM and the SB 13125-OFEK one ?
nobody ?
has nobody got any info on this ?
Old Nov 1, 2010 | 02:20 PM
biged681985's Avatar
there proabaly 30-40 pounds, and yes the southbend one is heavier
Old Nov 1, 2010 | 10:56 PM
Sudia247's Avatar
I know the flexplate is relatively light for a diesel part. I was expecting more metal but the main body of the OEM was pretty thin. As for the fly wheel I can't imagine them putting much more strength behind it. besides the added weight of the surface for the clutch to hit.
Old Nov 1, 2010 | 10:58 PM
rednekroper05's Avatar
i dont rember what my stocker was but my valair is probaly close to 45-50#
Old Nov 2, 2010 | 07:02 PM
angelic0-'s Avatar
wow, this is all heavy duty !
how heavy is the tranny and how heavy is the transfer case...
Old Nov 2, 2010 | 07:14 PM
Farmboy 2.0's Avatar
tranny is prolly 250 pounds with oil and the t case is 60-70 pounds prolly
Old Nov 2, 2010 | 09:54 PM
94 12valve's Avatar
depends on the t case and tranny I know the 271 t cases are a good bit heavyer than the 241's
Old Nov 2, 2010 | 11:49 PM
kazairl's Avatar
My South Bend DD shipping weight was 118lbs. That was the Pressure plate, clutch Disks and Flywheel.
NV4500s are 250ish
NV5600s are 360ish
G56s are 250ish
241 T-case is 100lbs
271 T-case is 120lbs
All the above are from DodgeRam.org
I would have to say a 47re(without fluid) is around 150-180lbs. That's using my calibrated method of grabbing onto it and heave ho.
Old Nov 3, 2010 | 05:50 AM
ztk7220's Avatar
sb's flywheel is heavy but i got it on and it's not that it is really heavy its that u have to hold it up and start the bolts in thats the hard part
Old Nov 3, 2010 | 10:10 AM
angelic0-'s Avatar
i'm not worried about being able to hold these things, i'm a regular strongman competitor, came in 2nd in Icelands Southwest regionals this summer...
i was just wondering how heavy they are, wondering if i should put it on a lift or if i could do it lying on the floor and if the flywheel was perharps lighter than OEM (not sure what effect it would have on a diesel but i put ltw flywheels on two of my BMWs and i thought they made better throttle response.)
