Cummins 855 turbo
Old Oct 31, 2010 | 01:03 PM
Powersmoke_sd's Avatar
Default Cummins 855 turbo
I have a used turbo off cummins 855 motor. No shaft play and no oil leaks. Not to sure on the specs but its a big turbo, good for a compound setup. $250 plus the ride. Can post pics if needed.
Old Oct 31, 2010 | 01:22 PM
Lil Red Express's Avatar
Pics would be great. What numbers are on it?
Old Oct 31, 2010 | 04:00 PM
I'll have to look and i'll try to get pictures tonight. The turbo is at my shop right now.
Old Oct 31, 2010 | 06:45 PM
Diesel Dummy's Avatar
depending on year of engine it should be an ht3b, big thing is size of ex housing, will be stamped on inside as well as cast on outside of housing.
Old Nov 1, 2010 | 12:04 AM
Can't find anything stamped on the exhaust housing. Looks like where is was, was maybe ground off. Here are some pics of it.
th_IMG_1809.jpg?t=1288587591
th_IMG_1810.jpg?t=1288587591
th_IMG_1812.jpg?t=1288587591
th_IMG_1813.jpg?t=1288587591
The tag for the comp side is gone and there are some numbers one that stands out is the ST50. Not sure if that helps or not.
Old Nov 1, 2010 | 06:12 AM
will be stamped on the inside of it where the exhaust flows in right on the flange area.
Old Nov 4, 2010 | 01:51 AM
It says A/R 75. Any thoughts?
200+ shipping?
Last edited by Powersmoke_sd; Nov 4, 2010 at 01:51 AM. Reason: Automerged Doublepost
Old Nov 4, 2010 | 11:59 AM
blazier18's Avatar
thats like a 14cm exhaust housing if im thinkin rite ill trade u my turbo for hx35w if u can find out if its t3 and the compressor and inducer mm ill give u cash if its wat i need
Old Nov 4, 2010 | 12:18 PM
Farmboy 2.0's Avatar
An HT3B turbo should have anywhere from a 22cm to a 32cm housing. And the compressor is a 74 or a 75 mm wheel i believe and a 90-100mm exhaust wheel or something like that as well. And it should be a t4 flange. At least mine on my twins it is. Here a pic of a ht3b by a hx35
Old Nov 4, 2010 | 09:11 PM
Get me the shipping cost to 82901 and How to get the money to you.
