code216
Old Oct 30, 2010 | 07:47 PM
dodgedad's Avatar
Default code216
scanner pulled p0216 truck is 2000 has a lope like a cam then clears but don't have good power blows white smoke
Old Oct 30, 2010 | 08:00 PM
crzycummins's Avatar
that code is sadly enough your vp44 failing...
Old Oct 30, 2010 | 08:06 PM
Yup. Time for a new one. (Make sure you get one with new electronics)
And a good lift pump and fuel pressure guage if you dont have one.
Old Oct 30, 2010 | 08:41 PM
DobermanDiesels's Avatar
you know i had that code white smoke and all and my local shop told me to change the speed sensor in my trans and i did and it fixed it and never had the problem again they said that sensor tells the vp how to fuel along with other things but the sensor went bad and threw the pump timing off its a 20 dollar sensor and its worth a shot man
Old Oct 30, 2010 | 09:38 PM
good point - that code can be generated by a number of things. its always best to clear it a few times to make sure it comes back.
Generally white smoke and hard starts when warm are telltale signs that your pump is shot.
