2006 6.0 questions on turbo and white smoke
hi i have a 06 powerstroke 6.0 and when my truck has not come up to temp it dumps white smoke out of my exhaust when i go to take off seams to get better when my truck comes to temp also when i lett off the gas peddle when the motor is still reved up my turbo makes a nocking sound and i was wondering if the 2006 moddle had some kind of blow off valve to dump not used boost my 2003 f-550 work truck does not do this?
The white smoke sounds like either coolant from the egr cooler or stuck spool valves on a few injectors. The turbo noise you here is called a turbo bark. When you let off the throttle sudenly the boost has to bo some where. Right back out the intake.
mattshow123
14
Mar 12, 2018 01:41 PM
Timglow546
8
Jun 3, 2015 10:13 PM
Fishy816
Jan 11, 2015 08:31 AM
