Super Rail Feed
Old Oct 30, 2010 | 08:59 AM
DEERE2500's Avatar
Default Super Rail Feed
i was wonderin what yall thought about the super rail feed from wicked diesel? if its even worth gettin or any advice i can get from it? im bout to get the stage 3 arrson kit and bigger conector tubes, i have 90hp ddp injectors, just want a lil info on it
Old Oct 30, 2010 | 10:46 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
First off the bigger connector tubes on a common rail is bad idea. Second if you think you need to get more fuel I'd add a dual feed line. The bigger pump to rail line is a good idea but the problem is that the size of the outlet of the pump and the inlet of the rail are still the same size.
Just for instance. My truck made over 1100rwhp fuel only with a stock rail, stock connector tubes.
Old Oct 31, 2010 | 10:02 AM
DEERE2500's Avatar
alrite thanks for the input, so arson kit and dual fuel like would work pretty good? im also gonna get fuel sump
Old Oct 31, 2010 | 10:53 AM
Jagsdiesel's Avatar
As long as your cp3 is in good shape and the supplu coming into it is good the asron three will run 90hp nozzels great.
Mar 13, 2015 01:50 AM
Mar 11, 2015 04:00 AM
