Fuel shut off relay
Old Oct 29, 2010 | 09:33 PM
MechanicalDiesel's Avatar
Default Fuel shut off relay
Has anyone on this forum tried one of these? NTE Electronics, Inc. - R51-1D70-12 - Sensors, Switches & Relays - Relays - Allied Electronics There a lot cheaper and seem like an exact replacement.
Old Oct 29, 2010 | 10:19 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i never tried one. it might work. i use a pull cable
Old Oct 30, 2010 | 09:27 PM
big willy's Avatar
you and me both pap my solenoid actually blew up one night when my truck was running. talk about being scared outa my mind thought the whole truck was gonna burn down.
but in reference to your question it should work if the plug in pattern is the same and it put out the same amount of power i really don't see why it wouldn't work
Old Oct 31, 2010 | 11:26 PM
Chevy355mark's Avatar
you know iv never even looked at my relay, the guy told me the solenoid was bad when i bought the truck. is the relay normally the problem or do the solenoids go bad?
right now iv got a lovely system of ropes and pulleys going into the cab. i pull a string every time i start the truck, all my friends get a good laugh outa it i almost dont even want to fix it, it fits the turd perfectly.
Old Nov 1, 2010 | 08:50 AM
Well I read around and the common problem is the fusible link and the relay, if your fusible link seems ok and aint soft, and your solenoid works sometimes but also doesnt work on other times than its probly build up on it or your relay. Otherwise if everything seems fine it could be the solenoid, but theres no harm in trying the cheaper stuff first
Old Nov 1, 2010 | 09:05 AM
cloker12's Avatar
Try LarryB's at fostertruck .com --Dodge truck starting problems are his specialty and his prices are good
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
