changing trans fluid this weekend
Old Oct 29, 2010 | 04:33 PM
01ctd's Avatar
Default changing trans fluid this weekend
hello again,
I was wondering If I should drive the truck around warmup the trans fluid before i replace the pan, fluid and filter? Or I should just park it overnight then replace the pan, fluid and filter following morning. Also i'm replacing the pan, fluid and filter not flushing the system, so i don't know if the fluid is +4 synthetic or not. I bought 10quarts of valvoline +4 synthetic should I worry maybe different brand of fluid??????
Old Oct 29, 2010 | 04:50 PM
motorboat's Avatar
Not really necessary to heat up the oil prior to draining the trans. Your going to get a little red anyway. LOL. Park the truck in neutral with the e brake on the nite before.
ATF+4 which is synthetic is the recommended fluid. Caution, correct fluid level is critical on these trans. Check it in nuetral after running it thru the gears. Dr,R,Dr,R,Dr, N= check.
You get the idea, right?
BTW, are you changing trans pan to one with more capacity?
Old Oct 29, 2010 | 04:55 PM
Lil Red Express's Avatar
Yap what he said
Old Oct 29, 2010 | 05:10 PM
01ctd's Avatar
B&M Deep Pan extra 4Quarts. I'll get some before and after pictures
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PA 24valve
Aug 31, 2015 07:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
DieselDan_5.9
Jul 30, 2015 07:05 AM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
