weird start?
Old Oct 29, 2010 | 09:46 AM
98dodgecummins's Avatar
Default weird start?
ok whenever i go to start my truck i have to turn the key and wait about three seconds for the truck to start,but if i just hop in my truck and not wait for about three seconds with the key turned on the truck wont start it will just crank crank crank.
Old Oct 29, 2010 | 10:18 AM
biged681985's Avatar
the three seconds is kinda mandatory. the problem ur having, is ur lift pump is over pressureizing the pump, cauing a hard start. if u let it the pump kick on, then back off, it will start right up.
Old Oct 29, 2010 | 12:40 PM
is this normal it wouldn't seem normal.
Old Oct 29, 2010 | 03:04 PM
24vcumminscowboy's Avatar
ya its normal its also for ur glow plugs to heat up some mornings when its cold ill sit there for a minute b4 i can crank it up
Old Oct 29, 2010 | 03:19 PM
a cummins does not have GLOW PLUGS. they have a grid heater that heats the air before it enters the motor.
yes it is normal for them to have to be waited on to start. u should always let the grids finish cycleing before u try and start the truck. the reason y the fuel pump runs for 3 seconds and then stops is because the vp44 is finicky. it will create a hard start problem if it is over pressurized while its trying to start. then as soon as the motor is running,the lift pump kicks back on and will continue to run till the truck is turned off.
Old Oct 30, 2010 | 12:43 PM
ok
Old Oct 31, 2010 | 05:14 PM
Wirtzy's Avatar
i had a problem with mine starting and it was the check valve on the return line. It was seeping air and i think causing pressure lose. got a new one and havent had a problem now. Other than the washers going bad but have new ones of those and it works great again.
Old Oct 31, 2010 | 05:50 PM
Dirt_Diver's Avatar
I think its funny how alot of people think a cummins has glowplugs or better yet how a cummins is the same thing as a powerchoke and durawax
Daniel Finney
Oct 22, 2019 01:58 PM
Cavnar
Sep 9, 2015 07:18 PM
thurobred1320
May 5, 2015 09:26 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
