KSB solenoid leaking fuel
Old Oct 28, 2010 | 08:22 PM
sweetv8s10's Avatar
Default KSB solenoid leaking fuel
Well its not really the solenoid leaking its the brass piece in the end which I think is a check valve but I was wondering if it can be taken out and if it has an oring seal that needs to be replaced?Any help would be appreciated.
Old Oct 30, 2010 | 10:32 AM
sweetv8s10's Avatar
Does anyone know what im talking about?
Old Oct 31, 2010 | 12:46 PM
sweetv8s10's Avatar
Can anyone help me with this problem?
Old Nov 6, 2010 | 10:46 PM
dieselsmokeaddict's Avatar
The fuel blow-by thing? Under where the banjo bolt is on the back of the pump??
Old Nov 7, 2010 | 10:24 PM
sweetv8s10's Avatar
If you are looking at the pump from the front of the motor its on the side closest to the frame down closer to the bottom it has a selonoid just like the fuel shutoff selonoid and on the other end is a check valve it advances the timing during coldstarts.
Old Nov 8, 2010 | 06:01 PM
crewcab59's Avatar
sorry to hijack thread but what is this. I dont think mine is hooked up ( a check valve it advances the timing during coldstarts )
Old Nov 8, 2010 | 09:44 PM
Could you get a pictue of where it's leaking exactly?
crewcab59: it's on the right side (if your looking at the engine strait on) of the pump below the manual shut-off switch. It has one wire that should be connected and one fuel line. I think it's a fuel line haha. You can hear a difference in the engine if you unplug it right after start-up
Old Nov 8, 2010 | 09:45 PM
sweetv8s10's Avatar
yeah my check valve is leaking fuel not the solenoid has anyone else had this problem?
Old Nov 19, 2010 | 07:38 PM
dannybacabe's Avatar
Default maybe
i have fuel coming out of the black thing under bango bolt and i took fuel pin out and there is fuel in there
Old Nov 20, 2010 | 01:55 AM
To fix the leak your gona need to take a day and replace a seal in the top of your IP. If you don't already have a 3200RPM spring in your pump now would be a good time to do so. There only like $20 at max and make a world of difference! You're gona need the rebuild kit for the pump also. It's like $20 as well. Heres how to fix that seal. Fix That Leaking Fuel Pin - Midwest Diesel Connection
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
WickedEvo
Oct 20, 2014 10:50 PM
