6.0 oil gusher!!!
Old Oct 28, 2010 | 07:29 PM
macer_81's Avatar
Default 6.0 oil gusher!!!
I just purchased a 2003 powerstroke from the bank as a none running truck. The only info the bank had was the engine was blown up. I got the truck and tried to start it starter was bad replaced the starter and it fired right up. The truck idled fine, sounds good but smoked like crazy and when you give it the throttle it revs but the you cant hear the turbo spool and no power above idle. I noticed a ton of oil under the truck after investigating I found that while running oil was poring out of the exhaust clamp on the back of the turbo. My questions are what are your guys thoughts, turbo or motor, and what should I check next?
Give me some ideas!
Old Oct 29, 2010 | 07:56 AM
Mdub707's Avatar
Are you positive it's oil? A lot of times when headgaskets fail, all of the coolant being pushed out and leaking into the exhaust will mix with the soot that is already in there and make it look like oil. I'd take the turbo off and see what you can figure out.
Old Oct 29, 2010 | 08:25 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Agreed with above statement. Also if it is oil. The icp sensor is in the hpop cover under the turbo. I have seen them leak oil bad enough to shoot it all over back there since it is 500+psi coming out.
Old Oct 29, 2010 | 03:56 PM
macer_81's Avatar
100% its oil there is enough of it coming out to be positive. Im going to pull the turbo to see how it looks. Im just thinking its the turbo cause you cant here the turbo whining at all when you rev it up and it has no power. it blows out ton of grey smoke when its running
Old Oct 30, 2010 | 10:28 AM
Mdub707's Avatar
You're not going to hear the turbo spool up when you're in park just revving it up. Not enough fuel is being pushed through to spool it at that point.
Old Oct 30, 2010 | 09:31 PM
macer_81's Avatar
When its in drive and it has a load on it you cant hear it spool. also the truck takes about 3 or 4 sec. to start smoking.
soco
Jul 27, 2015 06:06 PM
scubasteve12
Mar 29, 2015 09:39 PM
emilio2496
8
Jan 13, 2015 05:03 PM
ash23k
Dec 30, 2014 08:31 PM
iam1746regan
Dec 21, 2014 05:06 PM
