boost?
Old Oct 28, 2010 | 02:37 PM
shorty2tall's Avatar
Default boost?
how much boost is to much on a 94 stock head gasket and bolts?
Old Oct 28, 2010 | 02:53 PM
fivepointohno's Avatar
from what i have read on here around 50-55 with a retorqe
dont know how long that last though
Last edited by fivepointohno; Oct 28, 2010 at 02:53 PM. Reason: Automerged Doublepost
Old Oct 28, 2010 | 03:00 PM
Farmboy 2.0's Avatar
I dont like seeing over 40 psi without head studs. Anything above that and you run a good risk of blowing the headgasket anything below is relativley safe
Old Oct 28, 2010 | 03:32 PM
elledge12's Avatar
on my 95 i ran 40 psi maybe a little under for about a year and had no problems. the third day that i tightened up my boost elbow i saw 51psi and pop my head gasket blew. scott is right keep it under 40 psi for good reliability.
Old Oct 28, 2010 | 05:16 PM
ok thanks for the help
Old Oct 28, 2010 | 05:17 PM
Dirt_Diver's Avatar
If your gonna keep the stock turbo. i wouldnt go over 35psi.
Old Oct 29, 2010 | 03:08 AM
12vcumminspower's Avatar
What is stock boost I don't have a boost gauge yet what do they push stock
Old Oct 29, 2010 | 09:09 AM
12vpwr's Avatar
mines stock and im pushing 24psi. but im also running on 5 cylinders most of the time
Old Oct 29, 2010 | 09:47 AM
what if you have head arp head bolts instead of studs can you push it over 40?
Old Oct 29, 2010 | 10:49 AM
Apmcrx's Avatar
Usually in the 18-22psi range, depending on a few things... Auto/Man, Year, etc.
I only saw 16-17 or so before I added a boost elbow (not an adjustable one, just one with a small-calibrated orifice that came with the #0 plate.), then I saw 23ish.
I'm gonna block off the WG and see what it blows to on the stock turbo, with minor AFC mods (housing slid forward and 0 plate in the 'normal/mid' range. Was previously in FF but I wanted lower EGT's at WOT.)
