VP44 out the door
Old Oct 28, 2010 | 01:50 PM
ffemt44169's Avatar
Default VP44 out the door
Hey guys my 02 Cummins is acting up on me. The mileage has dropped to 10 mpg, blows way too much black smoke, misses on hard pull, and when ya let off the gas on a hard pull it will shut down, most the time wont start back up for a few hours. No codes in computer. Im not sure but I think the pump is failing. Do ya'll think its the pump? If so do you think i'd be better off replacing with another vp44 or just go ahead and P-Pump it? I mainly use the truck to tow the boat and occasionaly take it to the track to play. The truck has AEM Intake, removed silencer ring and blocked turbo(runs bout 35-40 psi), 100 HP Edge injectors, 150 AirDog, Edge chip, and 4" MBRP straight pipe. Much appreciated DJ
Old Oct 28, 2010 | 07:21 PM
yj junker's Avatar
try changing your fuel filters first,if you have not yet
Old Oct 29, 2010 | 07:17 AM
ffemt44169's Avatar
Just changed em, no change
Old Oct 29, 2010 | 08:00 AM
RAW's Avatar
RAW
What Edge do you have? Comp, EZ, Juice w/Attitude? If you have the EJWA, what is your fuel pressure doing?
Old Oct 29, 2010 | 10:08 AM
ffemt44169's Avatar
I have the edge comp i believe, but my fp gauge is stayin steady at 15 psi
Old Oct 29, 2010 | 11:19 AM
AF1CUMMINS's Avatar
Have you checked all your fuel lines and fuel line connections? Just a shot in the dark, but if you've got a leak, it may be suckin air and when you come off gettin a bunch of air in the line and causin you to shut down.
Old Oct 31, 2010 | 07:45 PM
Try running your truck without the Edge on it. Just to make sure its not the box messing your truck up.
Luke
Old Nov 1, 2010 | 06:49 AM
ffemt44169's Avatar
I am running it right now without the edge and I went over all the lines npf. Still have same problem
Old Nov 1, 2010 | 08:02 AM
crzycummins's Avatar
are you getting any codes???
Old Nov 2, 2010 | 09:04 AM
Turbolvr's Avatar
sounds like the bypass solenoid. I would just get a new VP, Ppump is not needed for this low of a power level and can be a challenge to tune. It will also fail you for emissions if your state is cursed with them.
