6.7l wastegate
Old Oct 27, 2010 | 07:42 PM
Young77's Avatar
Default 6.7l wastegate
im looking for a wastegate for my truck trying to prevent blowing a headgasket but im not to sure what kind to get.. what are you huys running on the 6.7s? i have the stock turbo still.
Old Oct 27, 2010 | 07:45 PM
Farmboy 2.0's Avatar
Your turbo cant build enough boost to blow a head gasket. And your truck has a wastegate already
Old Oct 27, 2010 | 10:08 PM
mikeshauling's Avatar
Boost isnt the problems with blowing a HG. Drive pressure is another story though. A set of ARP headstuds and an External wastegate will help A TON in preventing a HG failure.
Old Oct 27, 2010 | 10:19 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i sell them. black ops waste gates.
i hooked up a drive pressure gauge after i blew a head gasket. drive pressure gets high.
Last edited by diesel pap; Oct 27, 2010 at 10:19 PM. Reason: Automerged Doublepost
Old Oct 28, 2010 | 09:59 AM
SJG3RD's Avatar
I would do the studs first and then the wastegate, or both at the same time if the funds allow.
Old Oct 28, 2010 | 04:14 PM
brk126's Avatar
pull the head fire ring or o-ring it then arp 625's and a waste gate= problem solved
Old Oct 29, 2010 | 07:02 PM
Young77's Avatar
how much for all that..i guess ll just wait til it goes then send it out..
Old Oct 30, 2010 | 11:58 AM
dodgeram082500's Avatar
I agree with brk go ahead and fix it right the first time and be done with it (hopefully ) mine is being done a bit differently this time
Old Oct 30, 2010 | 06:32 PM
ETXBlueRam's Avatar
I'll second fixing it right the first time. It is a bit more expensive, but the money you spend to have the head gasket replaced a second, or even third time, will go a long way towards doing it right. Til you at least get studs in your truck, try to stay somewhat conservative with your timing, which will help keep the cylinder pressure down.
I do know there is something in the works right now for the 6.7 which should solve the headgasket problem once and for all. Once it's been tested and proven, it will be made public.
Old Oct 30, 2010 | 06:46 PM
