what to stack
Old Oct 27, 2010 | 01:58 PM
layedback40h's Avatar
Default what to stack
new to the diesel world about to build my trans and was wantin to know what would be good to stack with my edge juice/attitude
Old Oct 27, 2010 | 02:05 PM
Farmboy 2.0's Avatar
Smarty if you have the supporting mods like lift pump, turbo, injectors, cp3, manifold and intake
Old Oct 27, 2010 | 02:28 PM
ok thanks just lookin for some options
how do i get the hot unlock
Old Oct 27, 2010 | 02:36 PM
bobcat67's Avatar
edge will have it for sale
Old Oct 27, 2010 | 06:29 PM
print the form of their website and fill it out and fax it in.
Here is the Link to the hotunlockhttp://www.edgeproducts.com/product_...cle-pdf-32.pdf
Old Oct 27, 2010 | 07:23 PM
CreeperSleeper's Avatar
I'm interested in this too. I've heard that the Smarty just overrides the jwa, so I wouldn't go that route for stacking. To be honest, you would probably get more power out of some injectors before stacking. However, if you tow heavy, that may cause some issues with EGTs.
If all you have done is what's in your signature, I would recommend doing an intake, then an AirDog/FASS, then the hot unlock. If you still need more power, injectors, then a turbo, then stack with a MP-8 or something like that. *NOTICE- I am new to the diesel world, this is just what I have deducted from my research. Please correct me if I'm wrong!*
Old Oct 27, 2010 | 07:29 PM
The smarty does not override the juice we have a truck here at work running and edge smarty stack that puts down over 750 on a single turbo on straight #2. The edge smarty stack is one the the best stacks on a common rail truck. IMO
Old Oct 27, 2010 | 07:35 PM
That's good to know. Any details on the turbo? Does he have aftermarket injectors?
Old Oct 27, 2010 | 07:41 PM
silver 66, flux hellfire 4's, dual cp3's an intercooler etc.
Old Feb 20, 2011 | 08:43 PM
wiseguy63's Avatar
im new to the diesel world also i have a 99 cummins with a smarty, 90 hp injectors, boost fooler, airdog fuelpump, 4"exhaust and im getting propane injection in a week or so and i was wondering if the smarty stack with the edge juice would work if they were set on the right individual tunes so that it wouldnt be stacking the timing for instance im not sure what the edge tunes are but if you put the smarty on wild catcher without timing which is #8 and then the edge on the power setting with timing or vise versa because i know the smarty is low end power and the edge is high end and the edge may pick up where the smarty lets out. just as a theory i was wonderin if anyone has tried it?
