Puff of white smoke???
Old Oct 26, 2010 | 08:04 PM
06HarleyDavidson's Avatar
Default Puff of white smoke???
I just had new head gaskets, head studs, oil cooler, and egr block installed on my truck 2 weeks ago...i just noticed when i take off from a dead stop normal acceleration a small puff of white looking smoke comes out but only does it right when i push the throttle?
Old Oct 27, 2010 | 07:18 AM
Mdub707's Avatar
Will it do it in park or neutral? Try and see what it smells like. See if it smells like coolant, or fuel.
You say EGR block, did you just block off the cooler or the valve or delete both or what?
Who did the work? Did you get the heads decked and pressure checked?
Old Oct 27, 2010 | 10:11 PM
It does it in drive...like say stopping at a stop sign then going, right at takeoff. I have the egr valve. My buddy is a service manager at ford. So ford did the work.
Seems to only be doing it more when the engine is still cold. Like this morning I could see it good with headlights behind me going to work still dark outside.
Last edited by 06HarleyDavidson; Oct 27, 2010 at 10:11 PM. Reason: Automerged Doublepost
Old Oct 28, 2010 | 08:22 AM
Mdub707's Avatar
I see a haze behind me too with headlights, but during the day time I can't see it. How bad are we talking here? Hard to say without knowing if it's fuel or coolant, they can both look white.
Old Oct 29, 2010 | 04:07 PM
Just a small white haze right when I touch the pedal to go. It seems to stop once the engine is heated up all the way.
Old Oct 30, 2010 | 10:31 AM
Mdub707's Avatar
Try doing it in a driveway or something and see if someone can smell it. That will help tremendously. Other than that, I've seen plenty of 6.0's do this though. Could just be moisture built up.
Old Oct 31, 2010 | 02:23 PM
ranger518's Avatar
That is the same thing my 06 is doing gets worse when i am pulling a trailer but it to seams to get better when the truck warms up but some days it does not do it at all go figure and it is still under warraty but they will just say nothing is wrong with it so i am trying to find out for them let me know what you find out. Thanks
Old Oct 31, 2010 | 02:29 PM
will do man. i keep tryin to stick my head out the passenger window while im driving but i cant smell that far. so ill try and get someone behind me and get a whiff
Old Oct 31, 2010 | 02:39 PM
prison's Avatar
mine does it. its just cold. the cylinders are a little chilly. keep it on a block heater and drive it and i bet it wont do it. nothin to worry about
Old Oct 31, 2010 | 02:42 PM
ranger518's Avatar
yea but eaven in the sumer time when it is 100 deg outside mine will do it if it has been sitting all day. Like i fish alot and after a day of fishing (8-10 hours) my buddy will back my truck in and i will load my boat on it and when he pulls back up the ramp i will get a cloud of whit smoke in my face?
