fuel pressure drop
Old Oct 26, 2010 | 03:51 PM
crewcab59's Avatar
Question fuel pressure drop
after I turned up my pump ( ve )I noticed the truck would fall flat on upper end during wot. so I put in a fuel pressure gauge and found that it dropped to ( 0 ) psi so I put in a low pressure piston pump and I replaced the fuel line with a 1/2 inch pickup tube and 1/2 inch line all the way to the l/p ( I was there may as well do it right). I was expecting good things. come to find out it still dropped to ( 3 ) psi, better, but not good.
My question is, should this l/p be doing a better job than that, or is there something else wrong.
thanks for any input shane
Old Oct 27, 2010 | 06:02 PM
crewcab59's Avatar
OK...... does anybody else run the low pressure piston pump and have had this problem with these mods. am I expecting too much from this pump???
thanks shane
Old Oct 27, 2010 | 09:19 PM
Richie O's Avatar
I can pull mine down to 3 as well. 6x16's tuned to 300 horses. I have all stock fuel lines.
Old Oct 30, 2010 | 04:44 PM
crewcab59's Avatar
doesn't that mess with your timing? I thought any thing under 8 psi was hard on things.
Old Oct 31, 2010 | 12:59 AM
Richie O's Avatar
A stock diaphram style is lucky to have 5 psi max. My stock one had 3 to 4 psi tops after the filter.
Old Oct 31, 2010 | 10:52 AM
RSWORDS's Avatar
Yep, your pressures are ok, not ideal but about all you can ask for. Try a little timing bump to get some top end back. 1/8" should do it.
Old Oct 31, 2010 | 01:27 PM
crewcab59's Avatar
I did bump it up abought an 1/8. I have been reading some old threads on the dynamic timing spacer, although i havent decided what to do yet. thanks for the info.I guess I wont expect much more from my l/p.
Old Nov 1, 2010 | 12:00 AM
dieseldawg's Avatar
in my opinion the only way to go is a proper electric fuel pump thats designed for 1/2" + fuel lines!!
my pumps is a carter performance series it puts out 18psi at the pump and i can pull it down to about 15psi at full throttle!!
i noticed a big gain in the top end!!
Old Nov 1, 2010 | 01:35 PM
crewcab59's Avatar
do you have some numbers off of the pump by chance?? I am considering this route. thanks
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
cummins4inch
Jan 5, 2015 04:53 AM
