Low boost issue?
Old Oct 26, 2010 | 08:05 AM
B-Money's Avatar
Default Low boost issue?
Hi, I have an 03 f-350 6.0. I just got it fixed, it completely died on me a couple months ago. I replaced the IPR,ICP,OPS,CKP,HPOP,and fuel pump. But now its building low boost. Its only building 20 pounds under load. Could there be stuck vanes in the turbo or is it completely shot? If anyone has an idea what it could be please let me know before i go and spend money on a new one.
Old Oct 26, 2010 | 08:19 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Are you getting any codes? No it will not trip the CEL. Scan it and see.
Old Oct 26, 2010 | 08:36 AM
B-Money's Avatar
Im not getting any codes. I have checked it a number of times already. The only thing i notice is when i get into the higher rpms it gets a bit sluggish.
Old Oct 26, 2010 | 08:42 AM
Jagsdiesel's Avatar
Any smoke? A stuck egr can cause this issue. So can stuck vanes in the turbo, or the actuator on the side of the turbo.
Old Oct 26, 2010 | 08:50 AM
B-Money's Avatar
The only time my truck smokes is when i first start it in the mornings, it smokes for about thirty seconds and then clears up. But under load it does not smoke at all. And the EGR is not stuck i had that checked outh already.
Old Oct 26, 2010 | 10:03 AM
Mdub707's Avatar
How many miles on the truck? Could be vanes. How is the truck used and how often is it used?
Old Oct 26, 2010 | 12:25 PM
B-Money's Avatar
It has 350,000km. It is used every day to go to work and back and it does a fair amount of pulling cause i use it on my dads farm. So it hauls cattle, hay, and farm machinery.
Old Oct 26, 2010 | 01:07 PM
Mdub707's Avatar
Well it's usually a good thing if it has been worked, it keeps the turbo cleaned out. I would first go through and inspect all the rubber boots for cracks or possibly leaks. It's quite possible with that amount of miles. If those check out, I would go ahead and do the the turbo reconditioning process, it's sort of time consuming, but it's pretty straight forward and inexpensive to do. Worst case scenario, you have a clean turbo when you're done.
Old Oct 26, 2010 | 02:34 PM
B-Money's Avatar
Ok thanks. What do i all need in order to clean the turbo? I know how to take the turbo off the truck but when it comes to taking it apart im a little unsure how to do that? Is there a special way that im supposed to take it apart and put it back together? Some insight on this would be greatly appreciated.
Old Oct 26, 2010 | 03:19 PM
Mdub707's Avatar
Diesel Technician Society
Here's a good way for solving all 6.0 problems too... Power Stroke Diagnostic 8 Ball
haha, I love that thing!
