he 351vgt on a 12v
Old Oct 26, 2010 | 07:10 AM
Heavy Smoker's Avatar
Default he 351vgt on a 12v
I've seen people do he 351vgt turbo swaps on 12v p7100 and 24v vp44 cummins. Ive seen fleece performance makes a wiring harness for the 24v, but ive seen people ditch the electronics on the 12v and use air actuators. I have the 98 12v that has the obdII I was wondering if I would be better off with the wiring harness or with the air actuator.
Old Oct 26, 2010 | 07:52 AM
Apmcrx's Avatar
I cannot remember the name of the thread, but in the "Show and Tell" section, there's a guy that has one setup on his 12v. He used an actuator IIRC.
Let me try to find it for ya.
Edit: It's mkriebs's "Project Rusty Revival"
100_4628.jpg?t=1286842037
Hope it helps in your decision making process. I haven't done much research on 'em to tell you anything. Just saw this the other day in another thread and figured I'd pass it along.
Old Oct 26, 2010 | 09:33 AM
96blackcloud's Avatar
im also looking into a vgt for my 12v where can i find the acuator and adapter mount? also what wil these he351 vgts run boost wise in comparison to my stock hx35 will it be a worthy upgrade?
Old Oct 27, 2010 | 07:29 AM
I seen he 351vgts go for 200 on ebay.
Old Oct 27, 2010 | 07:44 AM
Apmcrx's Avatar
^ Yeah they are very cheap. After the adapter plate and actuator rod and oil lines (if you so choose), you might be looking at about $4-500 total, so IDK if it's a worthy choice for the 'trouble.'
I'm stickin' with my S300 plan... Simple, straight-forward, and headache free.
Old Oct 27, 2010 | 08:27 AM
well for the adapter plate your better off milling your own. Turn down an actuator rod on the lathe, and buy some cheap steel braided oil lines. Ps grind the port to a one port rather than a two.
Old Oct 27, 2010 | 08:33 AM
i did a bunch of reasearch on it yesterday and it seems to be worth it there was three main ways guys were hooking them up, one with a choke cable which was kinda rigged but worked good and you can still use the EB which is a plus, others where using springs to hold 12-15psi be for opening and others where using a pnumatic actuator which seemed to work well. i watch alot of video on it and the 12v with the vgt sound amazing let alone the spool up on them was very fast. im unsure as to how strong they are and how many pounds of boost they will hold up to though
Old Oct 27, 2010 | 08:38 AM
Im not gonna lie that choke cable sound like a good idea cause you can change the vanes on the fly, It would get annoying though after driving with it i bet.
Old Oct 27, 2010 | 11:09 AM
5.9Bronco...eventually's Avatar
Well you guys keep talkin about the he 351vgt, I saw on dieselpowermag.com a guy with a 6.7L take a he451vgt and put it on. He runs pretty good from the readin. I think someone should throw on a 451vgt and try that out
Old Oct 27, 2010 | 12:51 PM
the he351 ve can be had for cheap hence the reason i picked it check these videos out pretty impressive if you ask me
