low voltage
Old Oct 25, 2010 | 11:12 PM
jake 94's Avatar
Default low voltage
Hey guys for some reason when I first turn the key on my truck I have really low voltage the needle drops to almost 8 and then I start it and it starts fine and volts go up after about 20-30 sec. Can you guys help me out I'm stumped
Old Oct 25, 2010 | 11:47 PM
kingbrad89's Avatar
Default low voltage
So it starts fine? Where do you live is it cold there? If so it's most likely just your grid heater cycling to heat the intake air when the engine is cold. It draws some serious power. You'll notice your headlights and soforth dim when the grid heater cycles, it's normal until the truck is warm. I wouldn't worry about it if it's starting fine
Old Oct 26, 2010 | 10:43 AM
jake 94's Avatar
Ya truck starts fine lift pump runs a lil slow till volts go up and it isn't to cold here bout 35 degrees at coldest
Old Oct 26, 2010 | 02:40 PM
kingbrad89's Avatar
Default low voltage
The grid heater will circulate at 35degrees for sure
john grossman
10
Jan 12, 2019 08:58 PM
soco
Jul 27, 2015 06:06 PM
Saams69
Jul 20, 2015 11:21 PM
robbyS
Apr 16, 2015 02:22 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
