Advance Timing
Old Oct 25, 2010 | 06:35 PM
Neibe's Avatar
Default Advance Timing
How much should I advance my timing? All I have added is a #10 plate BHAF and straight piped.
Old Oct 25, 2010 | 06:54 PM
lodal cummins's Avatar
16 degrees max with stock head bolts
Old Oct 25, 2010 | 08:53 PM
94 12valve's Avatar
stock injectors?
Old Oct 25, 2010 | 09:11 PM
Neibe's Avatar
yes 215hp. when i replace the injectors what should i go with
Old Oct 25, 2010 | 09:16 PM
shortbusdriver's Avatar
You think you cant run more then that on stockers?
Old Oct 25, 2010 | 09:35 PM
sure you can but the head gasket will not hold up and i think u run the risk of stretching the head bolts. but what do i know
Old Oct 25, 2010 | 09:59 PM
You can run more then that and the gasket will hold just fine as long as you dont try and blow it running it cold or beating the fark out of it. Running 21º on our current truck with stock bolts and gasket and that truck is treated like a $50 hooker.
Old Oct 25, 2010 | 10:11 PM
94 12valve's Avatar
not all trucks will last like your "$50 hooker"
Old Oct 25, 2010 | 10:33 PM
blazier18's Avatar
mine was a 8500$ hooker wwhen i bought her and she aint put out since i changed tips LMAO
Old Oct 25, 2010 | 10:40 PM
Did I say you should run 21º? No, just giving an example.
blazier18, your pm box is full.
