7.3 IDI Turbo wont shut off!!!!!!!!!
Old Oct 25, 2010 | 06:05 PM
hxjetski's Avatar
Default 7.3 IDI Turbo wont shut off!!!!!!!!!
Came home today and turned the key to the off position but the truck kept on running, so I unpluged the plug with the three wires on the pump still kept runnining so I umpluged the other two wires on top of the pump and it still kept running? In the end I tapped the top of the pump with all the wires unpluged and the truck turned off? pluged everything back in and the truck started and turned off ok? what is going on and how can I fix it. I would really appericate it if someon e could help me Thanks
Old Oct 25, 2010 | 08:15 PM
agent_123_2000's Avatar
you have a very ambitious 7.3 id say!!!!
never ad this issue but id think the shutoff solenoid is sticky
Old Oct 25, 2010 | 08:26 PM
hxjetski's Avatar
How can I clean that???????
Thanks Terry
Old Oct 25, 2010 | 09:14 PM
DieselCrawler's Avatar
remove your fuel filter. fill with dieselkleen. reinstall and run. if that doesnt work the solinoid might need replacing.
Old Oct 26, 2010 | 08:09 AM
hxjetski's Avatar
Where can I buy a new solinoid? My Ford dealer sayes I have to buy the hole pump, at $1000 that seams to be overkill just to replace a solinoid. Does Autozone or someone like that carry that part?
Old Oct 26, 2010 | 02:51 PM
no autozone wont, and it can be a bitch to replace it. see if there are any pump shops around you. they should be able to get it.
Old Oct 27, 2010 | 05:48 PM
hxjetski's Avatar
DC do you have any pics on how to take that pump apart to clean or change that part.
Old Oct 27, 2010 | 08:33 PM
u should be able to just remove the top of the pump, but be carefull. there is a spring in there i belive. the top cover is just them 3 bolts.
Old Oct 28, 2010 | 06:21 PM
hxjetski's Avatar
Thanks DC I will give that a try
Old Oct 30, 2010 | 01:31 AM
rjjp's Avatar
When you put it back together be ready with a phone book, if the arm that sticks down is aligned wrong the engine can go into a runaway on initial start and then all hell breaks loose.
GarrettEvan
Jan 30, 2016 05:39 PM
Devon7.3
Sep 27, 2015 10:35 PM
g.logistics
9
Nov 22, 2014 08:54 AM
CO TOM
Oct 24, 2014 11:33 PM
CO TOM
Oct 16, 2014 09:55 AM
