truck problems
Old Oct 24, 2010 | 11:29 PM
blazier18's Avatar
Default truck problems
ok yesterday i got mad and pulled my injectors back out of my truck. i bought tips from bad *** ram. i put the tips in like 2 months or more ago and it still will barely start it has a bad white smoke to it and wont stay running. in a couple days im gonna have them pop tested. any ideas wat it could be would help
Old Oct 24, 2010 | 11:39 PM
Red_Rattler's Avatar
High Tech Redneck
What size are they? Everything was assembled correctly and went together with no issues? I'd def get them pop tested and see what's goin on with them. Could have a bad/cracked nozzle as well?
Old Oct 25, 2010 | 12:23 AM
blazier18's Avatar
he said they were 100hp but i dont think he knew for sure. im gonna take my stock tips and these tips and have each one measured to see if they are. but if the problem aint injectors wat else could it be. i also didnt replace any of the copper washers.
Old Oct 25, 2010 | 01:22 AM
jrad989's Avatar
any place that works on tractors could probably pop test them for you. and you should have also changed those washers but that wouldnt cause this much of a problem. and not to be rude but i would have recomended just buyin complete injectors from a reputable company next time. saves headaches.
Old Oct 25, 2010 | 08:12 PM
blazier18's Avatar
yeah no joke. i got in a hurry though but i hope its somethin small wrong with it. i just replaced the head gasket and had to have my head shaved
ok if its not the injectors after i have them tested and redone wat else is there to check. i think i have oil on my number 5 injectors. could just be diesel in there but i doubt it. and when i get the injectors back should i try to put them back in again or take my truck to citi diesel and let them put them in and all that good stuff. and one more thing is if its a bad nozzle can it be fixed
Old Oct 26, 2010 | 08:00 AM
Apmcrx's Avatar
I would assume you'd have to just get a replacement nozzle since they're so 'delicate.'
See what the test results are. If they're all good, put 'em back on and see what happens. Just work your way backwards through the fuel system. It's too hard to say what's wrong when it's not running, ya know?
And you're quite sure that you didn't/don't have any air leaks?
Old Oct 26, 2010 | 12:57 PM
blazier18's Avatar
idk iof they had air leaks any where idk wat torque they are. and the injectors slide rite out but before i had to pop them out
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
kalarachelle
Feb 21, 2015 03:25 AM
Oct 14, 2014 08:40 AM
