3.0 Pro Stock Pulling truck- FS/FT!!
Old Oct 24, 2010 | 08:57 PM
R&RDiesel's Avatar
FormerVendor
Default 3.0 Pro Stock Pulling truck- FS/FT!!
I dont really want to get rid of it but i have no time for pulling anymore and need to let someone else enjoy this truck. To tell you a little bit about it, it is a 1996 dodge ram 2500 frame and cab, standard cab long bed. I bought the truck to make this puller, and i started from the frame up. I completly tore this truck apart and built it the way i wanted it. So i will give you some of the things that makes this great puller.
1996 ram 2500
powder coated frame-dark silver.
rockwell f-106 axle in the rear, completely welded to the frame, with welded carier and thrust bolt installed. 6.20 gears.
dana60 front with locker and 6.17 gears and 35 spline axles.
pro fab drop box with 2 sets of gears
guted interior with hand throttle and all the saftey switches.
corsa datalogger with intellidash.
6k tack mounted on sheetmetal dash.
3-way fuel dump valve
2-way air shut off
nv4500 tranny with dual disk slipper clutch-only 4 hooks on it, and bellhousing blanket.
schied 13mm pulling pump with rsv gov.
schied built short block with shot peened and heat treated rods, 12.5/1 compression pistons, 14mm head studs and main studs, scheids block stiffner. clipped main bearings. 5x22 injectors, .120 ss lines. gear driven fuel pump with all ss braided lines. billet front cover and side cover. Roller rockers. Fully ported head with intake penulum cut off and schieds individual runner intake mounted instead. valves have hd beehive springs with titanium keepers and locks. fluiid dampner. schieds s400 3.0 charger with 4 hooks of freshning up. sure i am missing some stuff on the motor but that is the majority. I did have the motor dynoed at scheid after i built it and am pretty sure i still have the dyno papers.
Dual rear wheels with interco sts tires.
Fronts are mickey tompson classic 2's with :doh: i cant remenber what they are called but they are bias ply tires, but i do have the 2 sts also that i will throw in.
Bed is covered with a toneau cover.
truck is painted sunburst orane with some air brushing on the hood and tailgate.
Rear bumper was replaced with a roll pan
Has sled stops welded to frame that stick out through the roll pan.
Custom adjustable hitch.
Hood stack.
5gal aluminum fuel tank mounted behind the weight box i made for the truck, the dual cat batteries are also mounted behind the weight box bellow the fuel tank.
Dual electric fans.
Block is filled but still run water through the head.
13mm pump is self contained oil, i run amsoil in it and have changed it after every 5 pulls, truck has about 12-13 hooks on it.
I run vavoline racing 20w50 in the motor and have changed it every 3-5 hooks. I built the whole truck and put alot of money in the truck, no short cuts, have all recipts to prove it. I am sure i am missing lots of things but thats what i am comming up with for now. I am trying to sell out right but would be also willing to trade for heavy equipment of equal or lesser value, plus cash if need be, if you have questions or want pics please call me at 618-806-9779 or e-mail me at c_rohwedder@yahoo.com, I do have pics i can send to serious people. But dont hesitate to call or e-mail for more info, i am open to offers but like i said i have a price in mind and about the only thing i would trade for is equipment like tracked skid steers, dozers, excavators...etc. Thanks for looking, Corey.
Old Oct 24, 2010 | 09:24 PM
biged681985's Avatar
hey corey, sorry to hear ya gotta get rid of it. u need to bring it down to springfield mo this coming up weekend, may get some bites at the race/pull
Old Oct 25, 2010 | 09:26 PM
R&RDiesel's Avatar
FormerVendor
Hey Ed, hows it going? Ya i love the truck, but just dont have the time, wont make it there this weekend, but spread the word for me, its a graeat truck, thanks.
Old Oct 26, 2010 | 09:44 AM
cummins-dodge's Avatar
could i get pics and how much for the truck cummins-dodge@hotmail.com i am in IL also
Old Oct 27, 2010 | 08:14 AM
5.9Bronco...eventually's Avatar
Im not interested in buying I would just like to see pics of it. Come on mane. Post some up here
Old Nov 1, 2010 | 07:39 PM
R&RDiesel's Avatar
FormerVendor
Bump!!
Old Nov 1, 2010 | 07:43 PM
Red_Rattler's Avatar
High Tech Redneck
Price? Pics? Vids?
Old Nov 4, 2010 | 07:29 PM
R&RDiesel's Avatar
FormerVendor
Threre are some pics posted on comp diesel, in the trucks for sale section. Im working on the vid.
Old Nov 8, 2010 | 07:40 PM
R&RDiesel's Avatar
FormerVendor
Make offers or trades. Thanks.
Old Nov 13, 2010 | 06:40 AM
R&RDiesel's Avatar
FormerVendor
Anybody? This is a great truck, make offers or trades.
