bully dog question
Old Oct 24, 2010 | 08:11 PM
bullfrog8813's Avatar
Default bully dog question
Ok so I got this triple dog today just to see the difference between smarty and cl... I can't get the effin thing to connect to my truck. It just goes to the first screen and that's all... uh any help would be awesome
Old Oct 24, 2010 | 08:32 PM
bobcat67's Avatar
is the smarty unloaded from your truck? I'll tell ya now don't waste your time with crazy larry
Old Oct 24, 2010 | 08:44 PM
Yea smartyy is off... I'm bored, just want to see what would happen
Possibly get above 10mpg would be nice too
Last edited by bullfrog8813; Oct 24, 2010 at 08:44 PM. Reason: Automerged Doublepost
Old Oct 25, 2010 | 01:32 AM
IrishMan85's Avatar
Mine did the same thing when I bought it. Assuming you have the cable hook it up to your computer download the Update Agent from BullyDog and update it. That's what I did and it worked for me. I have the Crazy Larry as well and it makes good power you will probably find yourself watching your EGT gauge a little more if you load the Crazy Larry cause its runs pretty hot. I have a stock turbo, sticks and fuel system and I can see 1450 - 1500 degrees WOT and about that time I back out of it to attempt not to break or melt something. Haven't ran a smarty yet so i don't know the difference, but I personally like my BullyDog. Just my .02 cents!
Old Oct 25, 2010 | 07:15 AM
Tried to update it but it wouldn't ever load. I'm gonna call bully dog in a bit... I doubt egts will be an issue with my turbo. I'm kinda expecting the heat to be similar to edge.
Old Oct 25, 2010 | 11:17 AM
bobcat67's Avatar
if you update it i don't know if it will allow you to put crazy larry on it, not 100% sure on that but that is what i have experienced
Old Oct 25, 2010 | 01:11 PM
Ok got ahold of their tech support... determined that one of the buttons are fried... so I took it upon myself to hotwire it its uploading right now... ill work on downloading cl later... not bad considering I got it for150
Its amazing what a twisty tie from a loaf of bread will do
Last edited by bullfrog8813; Oct 25, 2010 at 01:11 PM. Reason: Automerged Doublepost
Old Oct 25, 2010 | 01:32 PM
5.9Bronco...eventually's Avatar
dang man. What are you doin to kill your mileage that bad. I know the lift and tires is killin you but geez. 10mpg is pretty bad. Do you have the 5.9 or the 6.7?
Old Oct 26, 2010 | 08:03 AM
5.9... idk but its bad. It took a nose dive when I put the turbo on. I still have smarty for when I wanna make big power, I don't have cl on bully dog yet but runnin bully dog on extreme and dr p I have less smoke down low, still enough power to spool, and I've seen an improvement on mpgs so I'm thinkin bout just runnin bully dog for everyday drivin.. oh yea... so far smarty is still the powerhouse..
Old Oct 26, 2010 | 12:23 PM
Is the turbo you put on that big? geez I wouldnt think a new turbo would kill mpgs that bad. My buddy gets like 20-25 dependin on how he drives but he runs smarty level 3 on his 06 with 35s
