starter problem?
Old Oct 24, 2010 | 05:26 PM
bowtech's Avatar
Default starter problem?
some time it start some time just clicks but i tap on starter and use to start now only click. i just put a new starter on few months back. now wont start even if i tap on it
Old Oct 24, 2010 | 06:34 PM
daveO's Avatar
You might want to look at upgrading the contacts and plunger:
LarryB's Dodge starting problems solved here.
I had similar problems with my starter and this did the trick.
Old Oct 24, 2010 | 10:54 PM
bowtech's Avatar
the small 8 mm nut on the starter that wire is the ground right? the whole stud spins is that normal
Old Oct 25, 2010 | 10:58 AM
daveO's Avatar
I believe the 8mm stud is actually the wire for the solenoid. The stud shouldn't be spinning.
Old Oct 25, 2010 | 11:07 AM
Stud should not spin. There is a repair kit ion the link above
Old Oct 25, 2010 | 05:14 PM
bowtech's Avatar
huh it spun when i got it out of the box from carquest
Old Oct 25, 2010 | 07:33 PM
how did you get the nut tightened then?
Old Oct 25, 2010 | 11:45 PM
bowtech's Avatar
when i torque the nut down hold the wire and it wouldnt spin
Old Oct 25, 2010 | 11:57 PM
blazier18's Avatar
bad ground happened to me
burndiesel
10
Feb 7, 2023 01:15 AM
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
