Turbo Identification Help!
Old Oct 25, 2010 | 12:24 AM
elledge12's Avatar
Default Turbo Identification Help!
My dad has an old mack truch sittin in the woods and i'm thinkin of takin the turbo for a twins setup i havent taken it off yet but i got the numbers off the schwitzer tag and i was hoping someone could tell me what it is and the specs.
Model:s3b-085
P/N:631gc5134p5x
S/N:L1699008r9
I know nothinng about it so any input is appreciated. thanks guys.
Come on i know someone on here has to know something about this turbo...
Old Oct 25, 2010 | 01:10 AM
bobcat67's Avatar
only thing I could find on anything was part numbers and replacement prices, i think your best bet would be to measure the exhaust wheel and compressor wheel and exhaust housing
found a few specs not much though, lookin at probably a 61/72 or a 61/80 not sure on the exhaust housing, probably in the 20's though, so it's probably around a 61/72/20 which wouldn't be any bigger than most upgraded turbos, it'll spool slower though, and like i said i don't know, but maybe this can help
nevermind with a little more digging i believe you're looking at an 83mm turbine with a 91mm compressor, still not 100% sure, that is something i believe you should look into, there's not alot of info out there
Old Oct 25, 2010 | 02:20 AM
elledge12's Avatar
Thanks for the help bobcat. and your right there isnt a whole lotta info out there but from what i found its an 81 turbine and 91 compressor like you said. I'll definitely just measure it up.
on another note if this did turn out to be a 83/91/??? what size exhaust housing would be best for a twins setup with my hx35? any help is appreciated.
Old Oct 25, 2010 | 01:14 PM
bobcat67's Avatar
I think you'd want to go with a 5" setup of some sort and even if it is an 81/91 that would be a good turbo for the atmospheric charger
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
