belts?
Old Oct 24, 2010 | 12:35 PM
green thang's Avatar
Default belts?
hey all i got the 7.3 with ac but took ac out "(too expensive to replace compressor) but my question is the belt that goes around the crank pully, water pump pully and to the alt. i replaced it after it snaped but it always has slack in it i tighteded it usins a breaker bar and still has play im just tired of replacing this belt every 1500 or so miles any suggestions or maybe i have it run wrong thanks tim.
Old Oct 24, 2010 | 03:12 PM
tiremann9669's Avatar
Is the belt supposed to go to the AC as well ?
Old Oct 24, 2010 | 04:15 PM
DieselCrawler's Avatar
the alternator drive belts always have some play in the due to the long run from the alt back to the crank. mine at idle would almost vibrate and hit the vac pump. i am gona throw out a guess and say u are tightening it way to tight. there is gona be play.
Old Oct 25, 2010 | 01:33 AM
Sycostang67's Avatar
I recently found this out as well, it's a common problem on these trucks. It was suggested that I get a shorter belt that only goes around the water pump and the alternator. Use a rope to measure how long it needs to be and take the old belt in so you will know the length and width you will need for the shorter belt.
Old Oct 25, 2010 | 03:43 AM
FordDZLMan9191's Avatar
So its normal that my alternator belt flops around a little when the engine is running? I think mines a short one already, I's have to look again to be sure.
Old Oct 25, 2010 | 05:44 AM
yea, she will wiggle.
Old Oct 25, 2010 | 05:34 PM
agent_123_2000's Avatar
mine flops like a **** in a shirt sleeve but its tight enough that it dont squeak
