burning oil
Old Oct 24, 2010 | 11:50 AM
Bigred7.3's Avatar
Default burning oil
my truck is going threw 5 quarts of oil every 2 weeks i have no clue y. its not leaking so it must be burning it up. it blows blue smoke some times. how do i fix this problem its getting worse every time.
Old Oct 24, 2010 | 03:58 PM
89_7.3idi's Avatar
sounds like your rings r TOAST 5 quarts in 2 weeks is quite a bit
Old Oct 24, 2010 | 04:17 PM
DieselCrawler's Avatar
i would try cleaning or replacing your cdr valve. it is the tune can looking thing behing the intake. acts like a pcv on a gasser.
also check air cleaner. that being dirty will make the cdr try and pull vapors from crank case.
Old Oct 25, 2010 | 12:33 PM
Bigred7.3's Avatar
If my rings were bad wouldn't I have no power? Cuz she deff has plenty of it.
Dieselcrawler.that cdr valve is where exactly I looked for it
Old Oct 25, 2010 | 12:50 PM
it is a round tin looking thing that connects to the intake. pulls vapors out of crankcase and into intake. has a spring and rubber diaphram inside it. the rubber part goes bad. let me see if i can find a pic.
Old Oct 26, 2010 | 05:56 PM
Bigred7.3's Avatar
Thanks the pox would b helpfull.
I cleaned the cdr valve but wen I pulled it out the hoses was so brittle it shatterd. I replaced the hoses but they wernt the hoses for it (temporary fix) all the auto places don't even have a listing for the cdr valve. After I put it bac togather the truck still blows blue smoke. Yyyyyyyyyy. I kno the injectors r bad cuz I have a fuel knock. Where can I get the cdr valve and hoses and how do I stop the blue smoke.
Old Oct 27, 2010 | 07:11 AM
ford still carries them.
Old Oct 27, 2010 | 07:07 PM
Bigred7.3's Avatar
i called them and they said they have never heard of that part and i called a diesel shop neer by and they dont kno wat that is eather.
Old Oct 27, 2010 | 08:39 PM
dumbasses. Contact the closest IH dealer if you want it cheaper then ford......
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A
IH part #1805319C1
Old Oct 28, 2010 | 06:01 PM
Bigred7.3's Avatar
Thanks the part numbers reel help. I'll probably order it tom. If that don't solve the blue smoke problem what will?
