Pinion nut removal
Old Oct 23, 2010 | 08:37 PM
collinscummins's Avatar
Default Pinion nut removal
I have a problem with the pinion nut, it doesn't want to come off! I bought a 950ft lb loosening air impact wrench and its not doing the job. I'm stumped to why I can't get this pinion nut off. I have 1 5/16 socket which is the correct size. Someone please help! Am I over looking something small?
Old Oct 23, 2010 | 08:43 PM
RAW's Avatar
RAW
I assume you are changing the seal, and that is why it is coming off? You can heat the nut with a torch, it will expand the nut and loosen any loc-tite in the threads. Just don't get carried away.
Old Oct 23, 2010 | 08:46 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have had to heat to get them off as well.
Old Oct 23, 2010 | 09:01 PM
will a propane torch get it hot enough?
yes changing the seal on it, along with the front axle seals haha! That axle seal where the CAD is located is giving me hell!!! I would like to hit someone on the head with a hammer who thought of the bright idea of how those dodge front ends go together! SHEESH talk about a PIA!!!
Last edited by collinscummins; Oct 23, 2010 at 09:01 PM. Reason: Automerged Doublepost
Old Oct 23, 2010 | 10:14 PM
RAW's Avatar
RAW
Are you talking like a BernzoMatic torch, or Oxy - Propane?
Old Oct 24, 2010 | 01:47 AM
benzomatic. Also i dont have a seal driver that big, what would someone recommend for driving that seal?
Old Oct 24, 2010 | 01:55 AM
Red Loctite (assuming its on there) releases at around 300 deg F
Old Oct 24, 2010 | 03:45 PM
tiremann9669's Avatar
Take a piece of exhaust pipe and a block of wood if you cant find one that fits get the next size smaller and stop at the local muffler shop and have it expanded to fit, also you're gonna need a hotter torch, oxy with acetylene or propane.
Old Oct 24, 2010 | 07:30 PM
ok thanks a lot guys, i appreciate the feedback
old chevy
Sep 2, 2015 08:42 AM
DeLuzGN
Mar 17, 2015 08:08 AM
mt grizzly
Jan 3, 2015 07:58 PM
Diesel_Daddy6.0
Dec 2, 2014 08:53 PM
cummalong69
Nov 17, 2014 02:43 PM
