Front seal
Old Oct 23, 2010 | 01:09 PM
Neibe's Avatar
Default Front seal
how hard is it to replace the front seal it looks like the oil leak is coming from behind the pulley that the fan is on?
Old Oct 23, 2010 | 02:22 PM
Red_Rattler's Avatar
High Tech Redneck
Thats exactly where the case likes to break because of the KDP.... Hope thats not the story but its not horrible, belt off fan and pully off (3 bolts) then undo all the cover bolts and it'll pop off. If the case is cracked or broke you in for a whole lot of fun... Tab the KDP while your in there!
Old Oct 23, 2010 | 03:12 PM
youre talking about the crank seal. As Red rattler said, its fairly easy.
fixing the kdp is very important do a little reading on that topic. A new crank seal will come with your kdp repair kit.
Old Oct 23, 2010 | 04:41 PM
bob4x4's Avatar
Pull the hub off........if the cover is cracked like red rattler said you are in for a bit more work than the seal.
Old Oct 23, 2010 | 07:36 PM
tiremann9669's Avatar
If the cover were cracked it would be gravy to fix it, it's the gear housing that usually cracks.
Old Oct 23, 2010 | 08:26 PM
Neibe's Avatar
My KDP was tabbed years ago I'm the original owner did it myself. Also after looking closer at it it looks like the vacuum pump this I have also done before.
Old Oct 24, 2010 | 12:12 AM
Vacuum pump seal kits can be had here - GOULD GEAR AND ELECTRIC INC.
Old Oct 24, 2010 | 03:48 PM
Those Gould kits are great, he sends the tools you need to do the job, plus extra seals incase you mess one up.
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Natenelson1
Jan 19, 2015 07:23 PM
natenel1
Oct 26, 2014 03:09 AM
