injector lines
Old Oct 23, 2010 | 09:09 AM
cummins-dodge's Avatar
Default injector lines
i would like to get oversize injection lines for a p-pumped 12 and also for vp 24 valve let me know what you have
01 dodge quad cab 5spd 275000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 300 hp injector, s400 turbo and s300 twins, custom billet intake plate, cooling mist water meth injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
pulling stats.
hanks 4x4 3rd 282.56ft
01 dodge reg cab 5spd 275000 miles cold air intake afe, cooler tubz, single electric fan, air dog 150, edge juice att. hot unlock, .093 connector tubes, valair single disc clutch, duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers
84 chevy k30 reg cab with 94 12v p pump cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, 370 injectors that are extude honed bigger, o- ringed and head stud, marine lift pump, custom ground cam, cooling mist water meth. injection, valair twin disc clutch 3850lb , 1 3/8 input shaft, valair hydulic upgrade, industrial injection silver bullet 66 turbo, no fuel plate, single 5 inch miter cut stack
pulling stats
hanks 4x4 7th 256ft
03 honda rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted 170 main , spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 12.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod, full skid plates, heavy duty racing clutch, jetted
07 Kawasaki klx250 on offroad bike moose air filter, fmf pipe mostly stock
