need help with my speedometer!
Old Oct 22, 2010 | 11:20 AM
blowinsmoke12v's Avatar
Default need help with my speedometer!
ok well i have a 1996 truck BUT my transfer case is out of a 1998 or newer truck (going by the transfer case shift lever) im being told the reason my speedo dont work is because it wont work with this transfer case and i cant find a sensor so is there a way to make this work?
Old Oct 22, 2010 | 11:31 AM
94 12valve's Avatar
the speed sensor is driven either off the output shaft of the t case or on the rear axel, sounds like yours cam off the t case. Look on the tailshaft of the case you should see where the speed sensor should mount
Old Oct 22, 2010 | 12:03 PM
can i make something up to at least have my speedometer working?
ok i just looked at it i didnt see any wires at all coming off the transfer case and i made a mistake i dont see anysensor for my speedometer just chilling under my truck...and on the rear i only seen a sensor dead center on top of the pump...is that it?
Last edited by blowinsmoke12v; Oct 22, 2010 at 12:03 PM. Reason: Automerged Doublepost
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
cumminsgen2
Oct 16, 2014 09:46 AM
